-   -   M12 Rx 471 binding issue (https://www.rctech.net/forum/radio-electronics/914898-m12-rx-471-binding-issue.html)
thartz36 02-28-2016 08:11 AM
Hey guys just got my brand new m12. And a 471 rx. I binded my buggy no problem.
And switch to model 2 and trying to bind my stadium truck. And as soon as i think its binded and go touch touch something it turns off. Sometimes it turns off within like 10seconds of me doing nothing.
This is brand new.
Any help please
Geezatec 02-28-2016 12:49 PM
press bind on RX, turn on power, LED goes off press enter on TX. after 10 second M11 time out, if times out, redo it from beginning.
brew99 02-29-2016 01:00 PM
make sure you are setting the correct modulation type for the 471rx on model 2.
Sabertooth 02-29-2016 02:12 PM
modulation mode is . FH3 / FH4T . as state I thnk this is your problem.
dan_vector 02-29-2016 05:50 PM
Wouldn't make any difference the rx471 is backwards compatible Fh3/Fh4.
Are these both separate receivers or are you moving the same receiver between the 2 models?
