Bullet connectors on motor >
Old 02-09-2016, 03:45 AM
Default Bullet connectors on motor
Hello,
Looking to run a race in 2 classes with the same car. 17.5 and 13.5 so I'd be swapping motors back and forth. Was thinking of going with bullet connectors on my motor to esc to make it much easier. Will I lose a lot of power do to the resistance or will it not make such a difference.
Thank you
Rcracing01 is offline
Old 02-09-2016, 05:47 AM
Won't make a difference.
Sully is offline
Old 02-09-2016, 06:30 AM
jordan860's Avatar
+1 with sully. The wire length will be the same so the resistance won't change.
jordan860 is offline
Old 02-09-2016, 02:25 PM
Suspended
Deans should be a good option
They are solid when plugged in, and have very low resistance.
The only way to know is by using a multimeter, cant get any simpler than that.
crankestein is offline
Old 02-09-2016, 03:33 PM
BULLET CONNECTORS ARE GOOD BUT THEY CAN WORK THEMSELVES LOOSE, I KNOW FROM EXPERIENCE. DEANS ARE MEH, QUITE HONESTLY YOU CAN TRY GOING BACK AND FORTH BUT DOUGHT YOUR LAP TIMES WILL BE THAT BIG OF A DIFFERENCE I HAVE RAN MUY 17.5 BUGGY WITH MOD AND 13.5 MULTIPLE TIMES FOR BIG RACES JUST TO GET MORE TRACK TIME AND USED THE SAME MOTOR.
jslider is offline
Old 02-09-2016, 03:41 PM
King DORK's Avatar
Trader Rating: 52 (100%+)
I used to solder female bullets to the solder tabs on the motor. Swapping motors was easy.
King DORK is offline
Old 02-09-2016, 03:43 PM
http://www.hobbyking.com/hobbyking/s...s_3_Sets_.html
these might be an option
jslider is offline
Old 02-09-2016, 07:06 PM
Originally Posted by jslider View Post
Those look pretty cool!
Gearhead82 is offline
Old 02-09-2016, 08:11 PM
hotrod87's Avatar
Trader Rating: 252 (100%+)
I use 4mm bullets from castle and tie down any extra wire and have never had a connector come apart
hotrod87 is offline
Old 02-10-2016, 02:59 AM
These look great. I'll order these up. Doesn't hurt to try for that price.
Deans makes a triple tab????
Old 02-10-2016, 04:18 AM
Did the same with one on mine, it works really well.
Sully is offline
