-   -   power supply? (https://www.rctech.net/forum/radio-electronics/910632-power-supply.html)
toepush 02-07-2016 08:44 PM
power supply?
What power supply do i wanna use with a 406 Duo icharger? At a 40amp charge.
QDRHRSE 02-07-2016 09:23 PM
This is all you need.
http://www.ebay.com/itm/Power-Supply...0AAOSwDk5UBQqj
fenton06 02-07-2016 10:02 PM
Smaller, cheaper, and more watts / amps than the one above. The guy also has higher wattage supplies and USB ports of you look at his other auctions.
http://x.amain.com/delivery/ck.php?o...roup%3D750x500
two shoes 02-07-2016 10:33 PM
QDRHRSE is on to something here... looking at the supply he provided... if you can solder or are at all mechanically inclined and can add a sticker wrap, these are just rack mounted server power supplies. Heck, most of them may have the 5v output and you could add a couple or USB tags to it.
Not much to it: new toepush PS
Socket 02-07-2016 11:41 PM
http://www.rchelination.com/setting-...-power-supply/
Christophoclese 02-07-2016 11:59 PM
http://www.ebay.com/itm/iCharger-12v...-/171890316639
12V 900W $55 shipped
Easily powers both channels at 40A on 2S (~672W). Nicely wrapped and quiet. Just big enough to set a 406DUO on.
toepush 02-08-2016 10:12 AM
First off thank you for all the feed back on subject. According to fantoms website ill need about 600watts.
road warrior 02-08-2016 10:44 AM
toe in order to get the 40 amps you need 18volts +..best to use a 24v..Id just build your own .either with 2 12v computer server supplies .or 2-12v atx comp ps..
from progressive site.. Maximum charge power: 1400W at >23.5V (1000W max. per channel)
team green 02-08-2016 02:17 PM
Can you discharge at 30amps with a 12v 75 amp 900 watt power supply.
Roelof 02-08-2016 02:29 PM
Discharging does not draw amps from the power supply.
team green 02-08-2016 02:55 PM
Thanks. I only ask cause I'm new to this regenative discharge thing. I have a 40 amp bank I set up to do a 30 amp discharge and I can only get to 20.5 amps.
Christophoclese 02-08-2016 05:07 PM
That's at 6S though. Far as I can tell toe is a driver and that means he's probably running 2S or 4S. Even charging 4S at 40A you'll only consume ~672W per channel.
You really start to 'need' 24V once you start working with higher voltage batteries.
djkurious 02-08-2016 06:55 PM
Here ya go: http://lipoconnectionsolutions.com/2...pplies_c14.htm
Andy Koback 02-08-2016 07:42 PM
P.S.
http://www.reilleymotorsports.com/#!...e-063f00d59b3e
