-   -   Testing old lipos (https://www.rctech.net/forum/radio-electronics/910327-testing-old-lipos.html)
rannblod 02-05-2016 02:14 PM
Testing old lipos
I have 2 SMC lipos 6500 mah 70c . I got them as extras in a deal when I bought a roller.. The guy informed me they have been sitting for over a year... I put them on the charger today both lipos were were at about at 3.55 each cell and balanced ... In power voltage 15.84 no puffing and the lipos are cosmetically in great condition... Do these lipos sound safe to use ..
Thanks Mike
I did try and research on some older lipo threads on Rc tech but I didn't, really find the answer I was looking for
Sully 02-05-2016 08:08 PM
They sound safe enough, if you're really not sure you could use your charger to discharge and recharge to check the capacity before running them. Just keep an eye on them while you do.
road warrior 02-05-2016 09:08 PM
so these are 4 cells and they cam off a charge at 3.96volts a cell... id say they are damaged and you will not get the output you will need.. use as long as they last ..check IR bet its HIGH.
rannblod 02-05-2016 11:05 PM
B 4.1 worlds
I ran them both plenty of punch and run time thanx for the info
Mike
rannblod 02-11-2016 03:34 PM
They are 2 cells / 2s my my charger does not have the option to check IR.. Just ran a pack for 35 minutes on a full charge and the were still sitting around 3.77 volts per cell. I do have my throttle turned down maybe that's helping with run time...and I'm charging these lipos outside that's there new home until I can get some new lipos..
dtr 02-12-2016 10:22 AM
3.96V is very low; do you have capacity cutoff enabled?
spookie 02-12-2016 10:30 AM
If they charge to 4.20 per cell, balance out nicely, discharge evenly, can take close or slightly over the total Mah rating when charging, I would say they are winners. Some batteries will take more than their Mah rating, I have some 5,000Mah that will take 5,400Mah and balance nicely.
rannblod 02-12-2016 12:39 PM
I have lipo cutoff set on my esc at 3.4 I'm not sure if that's what you're talking about.... I'm not very well versed in lipo knowledge... I just know enough to keep from blowing myself up..
rannblod 02-12-2016 12:43 PM
Yes they are charging and discharging nicely plenty of punch all the way until they hit lipo cutoff.. One lipo did have a small swell... barely noticeable after I ran it but it felt fine an hour later...
Geezatec 02-12-2016 08:13 PM
cycle the lipo's. good chargers have the option to charge and discharge up to 5 times. It may take 12 hrs or more. Longer it take the battery in good shape. Charger discharge at a 1amp rate. just takes patience.
dtr 02-13-2016 04:10 AM
Sorry I was not clear; I meant your charger may have a setting that limits how much mAh it charges into your packs, even if the desired 4.20V/cell is not yet reached. Your first post suggested that the pack was nowhere near at the end of the charge.
rannblod 02-13-2016 10:17 AM
I can see were you got confused on that. My bad... I meant that.s were the cells were sitting at after lying around for over a year.there charging fine... Thanx for all the input in this thread ... I do feel safe with these lipos
Mike
dtr 02-14-2016 12:56 AM
No problem, I wish you they will last long after surviving that high voltage rest.
