reedy 800z black box paired with 17.5 reedy. drat brake will not work x 2
#16
Talked to the tech, apparently the drag brake is 10 stronger in reverse than forward. So it looks like it's not working but it is. He said he got quite a few returned when they first came out due to this.
I had another issue so waiting to get it back again.
#19
The reverse brake is not drag brake and has nothing to do with drag brake. it is not adjustable in any way. This is set very strong so that the user can reverse his car and move into forward more quickly. The ESC is designed so that the user can't begin moving forward until the car comes to a complete stop. The faster it does, the faster you can begin moving forward.
#20
I just set up a 1000Z+ and assumed the same as everyone else here: that the percentage under Drag Brake is a percentage of the Braking power set under Brake Frequency; just like how Max Brake Strength is calculated. So according to what I've read then: Drag Brake is a percentage of the Max Brake Strength, and the Drag Brake coming out of reverse is 10x Drag Brake.
It would be cool if Drag Brake could act more like Max Brake Strength, that way we have direct control over the Drag Braking force.
#21
#22
The drag brake selections (limited unlike 410R) were based on the best options for 1/10 off-road and TC onroad requirements.
#24
Just bought the 1000z from Tower, same issue. No drag brake in forward, but it works in reverse. Manual Brake works. I run 17.5 blinky, when in neutral this speed control will show a solid red LED and a blinking green LED (F/B/R, 0° timing)
#25
I have similar problems. The drag brake only engage sometime, and the reverse is hard to get to work. I did recalibrate the esc several times, to came to the conclusion that the neutral range of the esc is way to narrow for the radio used. Actually I've experiment with several Spektrum radio and receivers, all leading to the conclusion that this esc should only be used with high-end radio. Their is no way to make it work on a Spektrum. It would be okay if we could adjust the neutral band width, but their no such tuning option on this esc.
I never had this problem with other esc. I might have to return it and run a cheap Hobbywing Juststock to match my cheap average driver Spektrum radio or get their fully programmable 510R.
#26
Rick, thank you for your response to earlier posts and taking time to hear our concerns. Any help with this would be appreciated by a lot of us.
