-   -   Where does my voltage protector plug in? (https://www.rctech.net/forum/radio-electronics/906029-where-does-my-voltage-protector-plug.html)
darbmaharg 01-04-2016 01:16 AM
2 Attachment(s)
Hi guys, I'm trying to figure out where my voltage protector plugs in, I'm running savox servos and a spektrum telemetry receiver, I'm presuming the lipo battery plugs into the auxiliary port which leaves nowhere for the voltage protector to plug in to, any help would be great, thanks
Rac3rX 01-04-2016 01:49 AM
Any open chanel
darbmaharg 01-04-2016 02:26 AM
The only channel left is where the bind plug goes, can I use that or do I need a Y harness off the battery?
Rac3rX 01-04-2016 03:06 AM
The Bind slot works, any open slot will work.
Although splicing it into the power leads is a good flex, not with a harness, better to plug it in the Bind plug slot if not directly spliced into the power leads.
darbmaharg 01-04-2016 03:09 AM
Ok then, the bind port it is, thanks mate
darbmaharg 01-04-2016 04:17 AM
If I choose to splice it into the battery leads what happens when I charge the lipo?
howardcano 01-04-2016 06:13 AM
DO NOT connect this to the battery or the power leads going to the ESC. It must be wired on the OUTPUT side of the ESC's regulator. An unused slot on the receiver is the best place.
This capacitor is to supply short spikes of current, drawn by the servo, that exceed the current limit of the ESC's regulator. Wiring it on the input side of the regulator won't let it do that.
Rac3rX 01-04-2016 07:19 AM
I apologize for being unclear. Not Battery power leads, the ESC power leads.
Ive had to run capacitors on my electric trucks, makes a huge difference when you need it. However I think he's running a Nitro so no ESC? Then just plug it in the Bind slot.
Nitro its always plug it in, plug it in.
For Electrics, though
http://www.castlecreations.com/products/cc-cap-pack.html
""""CC CapPack is designed for quick and easy installation. Users simply cut the soft silicone insulation on the battery wires – do this as close to the ESC as possible – and place the exposed wires in the channels on CC CapPack's posts. Check for proper polarity and then solder the wires to the posts. Use the included heat shrink to finish it off for a professional looking install"""""
I run it on my Big Block MERV because the demand of 1/10 electronics is too much on the small batteries that fit in the battery boxes. Without it throttle burst can trigger low voltage glitching, servos sputtering delayed take off and a bunch of other BS.
If your not gonna splice it on a ESC, plug it in the Bind port..
Electrics can alternatively plug one in the RX but splicing it in is better.
For charging? Cap is wired to power leads of the ESC NOT the Battery, battery plugs into charger no cap involved.....
Nitro though, its always just plug it in the open slot.
I should of been more clear
darbmaharg 01-04-2016 02:38 PM
Sorry guys, should have said I'm running nitro, I will use the bind port, all help is greatly appreciated
