-   -   Help with Tekin hotwire (https://www.rctech.net/forum/radio-electronics/902880-help-tekin-hotwire.html)
jason07 12-09-2015 04:34 PM
I just got my buggy up and running and this is my first time with the Hotwire setup. The car runs fine except it has no grunt down low and it takes a second or do to get going when it does.
I messed with the neutral width a bit but I don't know what will get me more grunt down low. I put the current limiter at 100 also. I just need a little schooling here.
I have a Dx4 pro and I changed the frame rate to 5.5 and I did re bind. (If that matters)
Here is my setup
Tekno eb48.3
Rx8
Tekin 1900kv
5000 mah 4s
HiTec 7950 servo
Any help would be appreciated.
Geezatec 12-10-2015 12:20 PM
mess with the throttle profile, then timing and boost. Timing and boost only seen Hotwire,
Andy Koback 12-10-2015 12:43 PM
Here is my setup
Tekno eb48.3
Rx8
Tekin 1900kv
5000 mah 4s
HiTec 7950 servo
100% on current limiter may be the problem. From Tekin: Putting the slider in the UP position, (off) disables the limiter and allows full potential power of the system". Worth a try.
jason07 12-10-2015 10:10 PM
I'm an idiot, I had the traction activated on the transmitter.
Once I turned it off, the car is perfect!
Thanks for the help
