Maclan Racing Products Discussion >
Like Tree160Likes
    Hide Wikipost
Old 08-30-2018, 09:59 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Maclan Racing Products Discussion
Last edit by: Cain
Updates here
Print Wikipost
Old 04-16-2018, 06:18 AM
  #1426
Pekr.da.skurl's Avatar
Bought a new Pico and ran it for about 30 minutes and it shut off. Has a single red slashing led and wont do anything. Anyone seen this?
Pekr.da.skurl is offline
Old 04-16-2018, 07:07 AM
  #1427
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
anyone got a V2 17.5 motor new in box they want to swap for a 13.5 V2 new in box?
Cain is offline
Old 04-16-2018, 07:07 PM
  #1428
I have a bue and red light flashing on my picco esc. It has signal and the battery is not low on voltage. Need some help, any one with experience with this brand or from someone at Maclan
RsA89 is offline
Old 04-16-2018, 07:41 PM
  #1429
Think I found the problem. I dropped my controller last time racing, messing with the neutral position, so when I turn on the ESC it thinks the controller is being pulled, a safety function. When I find neutral it starts up, it makes the start up noise. Still does it after being calibrated.
RsA89 is offline
Old 04-17-2018, 09:20 AM
  #1430
nikos2002's Avatar
Trader Rating: 30 (100%+)
Could try using a different model in the radio, each model will have its own unique neutral and end points. Re-Calibrate esc of course, with this change. You could also see if your transmitter has a calibration function to reset neutral, again re-calibrate esc. The esc will do what the signal from the radio is telling it. But if it the radio was damaged or something changed after the drop, the esc may not understand what the transmitter is trying to say.
nikos2002 is offline
Old 04-17-2018, 02:14 PM
  #1431
nikos2002's Avatar
Now available!!! ESC Software updates!! New Panel!! Updates and now Telemetry!!!! Check out the details here....
Maclan releases new 3.0 firmware platform for MMax Pro and MMax Pico ESC's :: LiveRC.com - R/C Car News, Pictures, Videos, and More
Holmestead likes this.
Old 04-17-2018, 07:29 PM
  #1432
Tech Legend
Cain's Avatar
as part of this update does it correct the power loss issue when the speed control allows reverse?
Cain is offline
Old 04-17-2018, 08:58 PM
  #1433
Telemetry sounds exciting!
Redesigned boost and turbo algos? Will we be expecting that we'll need to tweak our boost and turbo settings??
WagwanBumba is offline
Old 04-18-2018, 10:44 AM
  #1434
Installed new firmware fixed my esc's logic lock.
Old 04-18-2018, 11:00 AM
  #1435
nikos2002's Avatar
The short answer is yes. No set up is exactly right for every person, track or driving style. You should attempt to tweak it little by little to give you the best performance. When we set up a profile we have an object of trying to make it fast its purpose, but so much on the limit that it can cause someone to overheat something. That being said, when ever you try a new setting or set up - you have to be mindful of temps. Don't go out and try and run 10 minutes with a new boosted set up without knowing how fast the heat builds up.
Goof likes this.
Old 04-20-2018, 12:11 PM
  #1436
Tech Legend
Cain's Avatar
is there a recommended FDR to start with the for the maclan 17.5 V2 motors in 1/10 2wd buggy?
Cain is offline
Old 04-20-2018, 01:00 PM
  #1437
Trader Rating: 14 (100%+)
Cain, I’m running the preset 2wd blinky program. I just adjust the brakes and punch to suit the traction level. I generally run the throttle freq at the lowest setting and the brake freq in th low to mid range (sorry I don’t have the exact settings right now).
Rlmxracer is offline
Old 04-24-2018, 05:03 PM
  #1438
Trader Rating: 16 (100%+)
Hi, newbie when it comes to electronics. Can someone tell me what is the use of the sensor wires on the brushless motors?
Where does it connect? or do you use it only for servicing or adjusting the motor? I have a Maclan 21.5 short stack paired with a
Maclan Pico 100a. Sorry if this has been discussed, but I can't seem to find an answer to this.
Thanks in advance
sonny8692 is offline
Old 04-24-2018, 05:55 PM
  #1439
EbbTide's Avatar
Trader Rating: 39 (100%+)
Thanks in advance
the sensor wire is necessary and it goes from the motor to the ESC. The sensor wire plugs are keyed so plugging them in backwards should not be possible. The sensor port should be easy to find on the motor. The port on the ESC is under the solder tabs
EbbTide is offline
Old 04-24-2018, 10:01 PM
  #1440
Thank you for the info. On another note, I might have solder blend in from the A to the B connector on the motor. How critical is this?
