Maclan Racing Products Discussion
#1306
Here is the email:
ian.maize(at)hobbyauthority-dist(dot)com
#1307
Hey guys, did something a bit dumb today. I accidently connected the the battery around the wrong way which caused a lot smoke and maybe a little flame from the capacitors of my Pico ESC. I'm hoping only caps have died. I'm going to order a new capacitor module but the only supplier here in Australia has the 3 capacitor module that's on the MMax Pro. Will this work with the Pico?
#1308
On a side note, the 3 capacitor bank will work, it is just not necessary.
#1309
Another question, I plan to run a 5.5 turn Maclan V1 motor in 1/10 4wd buggy with the MMAX Pro ESC. I would like to use the fan on the ESC as well as a fan for the motor.
I plan to direct wire the fan going to the motor to the battery posts on the maclan ESC to give it direct power (maclan 30mm Fan), and then just run the ESC fan off the ESC port.
Are there any concerns about browning out the BEC (set at 7.4V) with this setup? I know I saw some oddities when running the fan on the receiver for the motor and the ESC fan, so just trying to confirm best wiring setup.
Lastly, what is stock timing ot use for this motor and any ESC setting tips?
#1310
Can you post what solution he came up with?
You should not have any issues with that setup
#1314
Got some interesting results! I cut the capacitor module off, plugged in a battery and turned the ESC on. It boots up as normal, the steering works, the lights show throttle and brake movement, but the motor doesn't turn. Will the motor turn without capacitors installed, or is the ESC stuffed?
#1317
As far as timing on motor 30-35 should be good,
Esc settings a higher throttle frequency will help smooth out that much motor, for brakes you will want to run a low frequency.
May want to limit punch as well depending how it feels.
-Ian
#1319
You should not have any issue with the fans.
-Ian
-Ian
One thing i would like to see maclan come out with is a fan similar to the yeah racing aluminum fan, heard these are significantly more durable.
#1320
I have a Tekno Shortcourse 410.3, with a 4000k Hobbywing. I know, it came with it. It is OK on speed. In the past, I had a 4300k Tekin, and it was crazy fast on our indoor clay track. I've not heard of anyone in this class run a 3500kv. Would this Maclan be fast enough, or go with the bigger Maclan 4100kv? These Shortcourse trucks are heavy. But the 3500kv says it is for these?
