Maclan Racing Products Discussion >
Like Tree130Likes
    Hide Wikipost
Old 08-30-2018, 09:59 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Maclan Racing Products Discussion
Last edit by: Cain
Updates here
Print Wikipost
Old 02-18-2019, 05:30 PM
  #1666
Originally Posted by Cain View Post
maybe some batteries could be made that "oneway" battery tubes where you can only plug in the right battery plug into it versus the dual smooth tubes.
That's an awesome idea!
Bman7649 is offline
Old 02-19-2019, 11:55 AM
  #1667
Tech Legend
Cain's Avatar
Trader Rating: 256 (100%+)
Originally Posted by NWracer77 View Post
I'm a racer, I can't remember the last time I used reverse LMAO
I am a racer as well. When trying out new driving lines in practice Its easier to hit reverse and get yourself out of a jam than coming down from the drivers stand moving the vehicle, and the going back up again. But yeah I agree in general its not something done often hence why its not a big deal unless you get like we do, a bit lazy and leave the feature on into the races lol.
Cain is offline
Old 02-20-2019, 11:05 AM
  #1668
RDNKTaz's Avatar
Originally Posted by Baja-Boy View Post
The iPhone app will come with our Bluetooth adapter, as the iOS environment does not allow the same usb connectivity of android OS.
Any time frame on this? I have all iOS and would hate to spend money on a cheap laptop and move everything to it. Even though I would have a dedicated device to rc racing and would make my wife happy.
RDNKTaz is offline
Old 02-22-2019, 03:16 PM
  #1669
nikos2002's Avatar
Trader Rating: 29 (100%+)
Don't have a time frame... but get a cheap Android tablet, easier to bring to the track than a laptop.
nikos2002 is offline
Old 02-23-2019, 02:57 AM
  #1670
RDNKTaz's Avatar
Thanks for the reply Niko but I have the latest iPad with all my setups sheets and data already on it. In fact, I’m use it for everything. Guess I’ll just use the program box until I can use my iPad.
RDNKTaz is offline
Old 03-06-2019, 08:32 PM
  #1671
RDNKTaz's Avatar
Any team drivers going to be competing this weekend at the Palmetto Classic at Beach RC?
RDNKTaz is offline
Old 03-11-2019, 08:31 PM
  #1672
BRSracing's Avatar
Trader Rating: 63 (100%+)
I am using a Samsung S8 plus phone to program my max pro esc. the issue I am having is it keeps disconnecting. Anyone else have that issue?
BRSracing is offline
Old 03-12-2019, 12:12 PM
  #1673
BRSracing's Avatar
May have it figured out
it was my phone not the ESC. Program works fine now.
Old 03-22-2019, 03:09 PM
  #1674
https://www.amainhobbies.com/search?cID=&s=HADMCL1015.
I have this motor for stadium truck.
I've never driven a 13.5 in a stadium truck. Where is a good place to start for gearing? Or better yet what is a good final drive ratio for stadium truck, and how do I figure out FDR. I have no idea, but I want to learn. Thanks.
EDIT** I used my Google Fu to find out about FDR. I would still like to know where I should start for gearing?
MaX-D is offline
Old 03-26-2019, 09:17 AM
  #1675
nikos2002's Avatar
What truck are you using??
Old 03-26-2019, 02:10 PM
  #1676
two completely different trucks, same ESC (Hobbywing Quicrun 10bl 120) and motor.......TLR 22T 3.0 for me and ECX Circuit for my son. Circuit has an internal gear ratio of 2.6., and a 87T spur in it right now.
I want my son to get his feet wet before I drop money on a race grade truck
MaX-D is offline
Old 03-29-2019, 09:09 PM
  #1677
Picked up a artr t6.1 with a maclan mmax pro, I cant seem to get the esc to calibrate with my 3pv transmitter.
3pv reset all settings
full reverse and turn on the esc, does the blinking as per manual. Blue light flashes and I go full throttle, blue goes solid and then turns off. Release to neutral and it makes a bunch of beeps. Then the blue and red blink but opposite of eachother, red blue red blue etc with no motor power
any input is greatly appreciated
Mr.fixit is offline
Old 03-29-2019, 11:12 PM
  #1678
Try a fresh model on the radio. Try and calibrate. If it will not calibrate, reverse the throttle channel on the radio and repeat.
trigger is offline
Old 04-09-2019, 01:34 PM
  #1679
I just installed a 13.5 short stack motor on my son's ECX circuit, and the shaft is too short for a Robinson Racing pinion. What can I do at this point?
MaX-D is offline
Old 04-12-2019, 08:42 AM
  #1680
metalcrafter's Avatar
Had repeat issues with the MMax -Pro . Randomly goes into a fault mode ( rapid red flashing led).
Only way to clear it , is to completely re-flash the firmware . Neither the android app on the phone or
tablet will do it , only from my windows laptop . PITA , who drags a laptop to the racetrack ???
Data log is way-off on the values , both rpm & motor temp. Use the data as a reference only ......
metalcrafter is offline
