servo/receiver issues
hi! was wondering if a bad servo would would make a receiver go bad or vise versa? am dealing with nitro 7.4 volt 2600 mah lipo/hitec 7955tg and airtronics rx-461 receiver.thanks!
I found if you have problems with a servo, it'll be the steering servo. When Ste ering servo is bad it will shudder or turn one way and throttle servo will do the same. Disconnect the steering servo, the Th servo operates fine. Replace the steering servo. You probably pop the circuit board in the st servo.
Never seen a Airtronics RX go bad in 30 yrs. |
| All times are GMT -7. It is currently 06:50 PM. |
