-   -   Motor specifications from dynos and etc (https://www.rctech.net/forum/radio-electronics/893700-motor-specifications-dynos-etc.html)
phatboislim 09-24-2015 01:14 PM
I'm curious, as i'm still kind of new to the numbers that are taken from a motor dyno or from a certified motor. What do those numbers signify? Like i'm guessing it's telling on its efficiency and/or power of each motor. But how do i decipher?
IE:
http://www.rctech.net/forum/attachme...32637756_n.jpg
evochick 09-24-2015 05:40 PM
my guess looking at those numbers its a 13.5 1s ??
first one is stator resistance of the 3 winds, lower the better
second is rotor strength, higher the better depending on application
third I believe is current draw, lower the number more efficient it is,
and RPM is well RPM,
I don't know if that helps you or not as you can only really compare how good it is compared to other same motors
phatboislim 09-25-2015 04:30 AM
thank you very much
Mudcat981 09-28-2015 04:03 PM
IE:
The specifications on the certified motor sticker are as follows:
Stator resistance values at 72 degrees F, these obviously are very temperature sensitive.
Rotor strength values at 72 degrees F.
Amp draw and RPM at 1 cell voltage (free rev).
Amp draw and RPM at 2 cell voltage (free rev).
Amp draws are set with the Gforce measuring machine.
wrongchannel 09-28-2015 09:23 PM
Remember that because standards and calibration differences between Dyno manufacturers, these measurements are not a true form of comparison. Every manufacturer has their own way of interpreting the numbers a Dyno can produce.
Personally I only use these test to compare motors is when I'm comparing other motors I have.
sk55 10-04-2015 04:22 PM
Do you really think Trinity is putting RPM and amp draw numbers on their motors with a Gforce machine? I would be willing go bet it is a Motolyser(exclusive distributor) and very accurate or a machine they built.
