Tekin RSX capacitor
ok, so, i just switched to onroad.. from 1/8 offroad, and we dont have capacitors soldered in the RX8 (internal as i understand)
anyway, the other day while doing some esc setup, and some playing with the data logger.. and testing some batteries.. i hit a bump the parking lot.. the battery plug came loose from the battery. so, i went to plug it back in, and there was a pop. not the typical, small pop (like when you touch a door after dragging your feet that i typically notice).. but.. a pop from the capacitor. little smoke, little nasty smell. the speedo still works, and everything seems fine, did i just pop a capacitor? where can i get a new one quickly, i have regionals coming up this weekend, and i dont think i can get a new tekin one in time. thanks fellas.. |
Originally Posted by dgrobe2112
(Post 14192400)
StormersHobbys.com. Part#'s TEKTT3518, 20, 22 & 52. Choice of capacitor required. 3552 good for 6S lipos
If RX8 shipped with Caps it should have installed. If not, Warranty maybe voided. I would take it apart, that will void also. Email Tekins for RMA. Takes 2 weeks. Caps don't burn they explode. If a component smell its a bigger problem. |
(Post 14192400)
anyway, the other day while doing some esc setup, and some playing with the data logger.. and testing some batteries.. i hit a bump the parking lot.. the battery plug came loose from the battery. so, i went to plug it back in, and there was a pop. not the typical, small pop (like when you touch a door after dragging your feet that i typically notice).. but.. a pop from the capacitor. little smoke, little nasty smell. the speedo still works, and everything seems fine, did i just pop a capacitor? where can i get a new one quickly, i have regionals coming up this weekend, and i dont think i can get a new tekin one in time. thanks fellas.. TT3520 is the correct part #. |
| All times are GMT -7. It is currently 10:07 AM. |
