Orion R10 Pro Problems
I have an Orion r10 pro, the original not the 10.1. My on/off switch is not working. Is there a way to splice the wire or get a new one to keep using this esc. I'm not sure what to do because the program button is on the switch. I have confirmed it is the switch and no other problem. Any help is appreciated. Thanks
splicing the red and black wire together will leave the switch permanently on, until you can source a replacement switch (such as used on Hobbywing esc's etc)
I have some hobby wing and novak switches. I just didn't know if they would work on the orion. I will cut it off and try tonight. Thanks.
Tried two new switches, Hobby wing and one from a novak gtb with program button on the switch, neither worked. Any other suggestions before I drop another 200 on a speedo?
Just order a new switch and wire it in? Unless I am misunderstanding your issue.
http://www.amain.com/rc-cars/team-or...FQ2BaQod_dIHGQ |
| All times are GMT -7. It is currently 11:51 AM. |
