-   -   RSX getting really hot while trying to program.. (https://www.rctech.net/forum/radio-electronics/885394-rsx-getting-really-hot-while-trying-program.html)
Sandfreak 07-20-2015 07:57 PM
Bought a used RSX andwhile trying to program it gets hot and smells. I have run my 22T 2.0 with a 10.5 and no fan for 7 minutes straight and its not even barely warm. Anyone else experience this?
MarkA 07-21-2015 08:41 AM
Used + Hot + Smells = Good time to contact the seller and ask what's what or send it to Tekin and have them take a look.
wrongchannel 07-21-2015 09:09 AM
Check to make sure both of the capacitor leads are still connected and aren't burnt. It's quite possible that the former owner used 4mm inboard battery plugs and reversed the polarity accidently. If so, it will appear to be working, but slowly smokes the circuitry.
BTW, If you see smoke and heat IMMEDIATELY REMOVE THE BATTERY FROM VEHICLE AND PLACE IN LIPO BAG.
let us know how things work out?
Andy Koback 07-21-2015 10:31 AM
Request a full refund and return to seller. File a pay pal claim if necessary. Should not be getting hot while programming!
Randy_Pike 07-21-2015 10:32 AM
Programming it with what? How? PC ? Android? Hotwire Gen1 or Gen2?
lbenton 07-21-2015 12:35 PM
You should not be able to smell your electronics, something is wrong and my guess is the same as 'wrongchannel' and you bought somebodies problem. An ESC that is momentarily hooked up backwards may work for a while, but the days are numbered and the number is small.
wrongchannel 07-21-2015 01:15 PM
->Sandfreak<-
Be sure to follow Randy's advise. He's "The Tekin Man" and can help you decide which way to go if you can't get a refund from the seller.
Sandfreak 07-21-2015 03:23 PM
Thanks guys. Didn't buy it on here. Its on its way back though.
