Hobbywing XERUN XR8 Plus >
Like Tree11Likes
Old 08-03-2015, 02:47 PM
  #61
Trader Rating: 27 (100%+)
what brand 1/8 motor run?
taztal3 is offline
Old 08-03-2015, 06:52 PM
  #62
Dan.J's Avatar
Trader Rating: 21 (100%+)
I got mine today, Its big and heavy compared to Rx8. Seem's well built (heavy duty) Here is a quick picture where you can kind of compare size. You can kind of tell these are a early run, I had no paperwork (instructions) in box (not that I really need any) and all the pictures I seen promoting this ESC showed red fan screws and mine has black. All trivial stuff that means nothing to me, I just care if it works well or not
Dan.J is offline
Old 08-03-2015, 07:30 PM
  #63
Just to clarify, these aren't going to be able to run sensored to Tekin motors correct?
That just seems like an awful decision on their part.
McGuire is offline
Old 08-03-2015, 07:47 PM
  #64
Dan.J's Avatar
Sure they will, what makes you think otherwise? They do have some special motors coming that will do some fancy stuff with this ESC is my understanding though. They will run sensored/unsensored or extra fancy sensored with the new Hobbywing motors that are coming is my take on it.
Dan.J is offline
Old 08-03-2015, 08:26 PM
  #65
http://www.falconsekido.com/products/xerun-xr8-esc
See bottom of details
McGuire is offline
Old 08-03-2015, 08:37 PM
  #66
Carter Flotron's Avatar
Dan.J is correct, they can run other motors. They just work better with the Hobbywing new ones
Carter Flotron is offline
Old 08-03-2015, 08:39 PM
  #67
Just curious why it would state that then?
Can anyone chime in that has an XR8 using a different motor running it sensored?
Nevertheless, if they actually can use other motors, Hobbywing might want to change the wording. Locally, they have lost a few sales due to "how" it is stated on their website.
McGuire is offline
Old 08-03-2015, 08:45 PM
  #68
Trader Rating: 55 (100%+)
best way I found to mount the switch in a tekno
Attached Thumbnails Hobbywing XERUN XR8 Plus-img_1810.jpg   Hobbywing XERUN XR8 Plus-img_1805.jpg
Yodah is offline
Old 08-04-2015, 03:12 AM
  #69
Dan.J's Avatar
Yea I thought about that, where do you plan to put the transponder now? Inside the box?
Dan.J is offline
Old 08-04-2015, 03:18 AM
  #70
Dan.J's Avatar
I will get my stuff setup soon and report back and I agree the wording on there website is confusing. There is no way they are going to release a ESC that would only run "there" motors properly though unless they wanted it to be a total fail IMO. Build quality looks good on this ESC from what you can see on outside and its priced right, if it works as well as I think it will it will be a winner
Dan.J is offline
Old 08-04-2015, 06:35 AM
  #71
Yeah its already in there
Yodah is offline
Old 08-04-2015, 10:12 AM
  #72
Isn't the SCT Pro better for 1/8 Buggy. That thing looks like a brick. They need to update the SCT Pro with the latest stuff.
My guess is that the Speed Control switches from Sensored to non-sensored at some point. So there is no clogging. The new motors will run sensorred all the time
Chris Reilly is online now
Old 08-04-2015, 10:54 AM
  #73
Dan.J's Avatar
Quality seems quite good on these, they are beefy but not crazy heavy. Like 125g for these and a rx8 is like 80g and sct pro is around 100g I think.
Dan.J is offline
Old 08-04-2015, 11:28 AM
  #74
tedstryker's Avatar
Trader Rating: 85 (100%+)
Is this bigger then the old 150a one?
tedstryker is offline
Old 08-04-2015, 12:59 PM
  #75
When someone figures it out where these ESCs can run other motors sensored please chime in.
I'm about to order a new ESC in a couple days and its between this or the new Orion 8.1
McGuire is offline
