Lipo help
I recently bought a lipo battery, with a Sky RC Imax B6 Balancing smart charger. The battery is a Turnigy nano-tech 11.1 V 1400 mAh airsoft style battery. Whenever I try to charge it on the B6, it says "Connection Break" and sounds the obnoxious alarm. Is there a way to fix this without sending it back or spending much money? I have a battle (I bought it for my gun) coming up and I want to be able to use my gun with it's battery. :cry:
Are you plugging the balance connector in? Little white plug with 4 wires. Then balance charge it at 1.4 amps.
Originally Posted by spookie
(Post 14014622)
Originally Posted by EpicElrod
(Post 14014531)
Before I did that, though, I would attempt to test the battery using a multi-meter (or purpose-built battery tester). First check the overall voltage at the positive and negative terminals and make sure it is higher than 9.6v. Then you can check the read out on each balance lead by using the positive lead on each balance terminal and the negative lead on the battery negative. If each cell reads out a voltage through the balance lead, try another charger or double check how the balance lead is seated. |
I had the same problem with the same charger i tried every battery type from lipo to nimh, nicd, and life kept getting same "connection break" check on youtube there was a person who pulled on apart and appearently fixed it. I dont think its your battery but could be wrong.
Well, thanks for the help guys, but I figgure it out! I need to connect the Tamiya plug along with the balance cable! Thanks again.
Glad you was able to figure it out I'll probably fiddle with mine again this weekend
| All times are GMT -7. It is currently 04:50 AM. |
