How do I charge two 2s batteries at the same time?
Hello all.
What do you guys recommend as far as charging two 2s batteries at the same time? My charger can handle up to 4s. I understand the whole concept of charging the two batteries in parallel. My questions though is how do I do balancing if there is only one battery port on the balance board? Can someone recommend or link me to a balance board I can use where it can balance both 2s batteries being charger in parallel? Or do you guys recommend I charge in series so that the charger sees the two 2s as a one 4s battery? I use a Duratrax Onyx 235 charger. What do you guys recommend and do they make board that can have two 2s battery balance plugs connected to it at the same time? Thanks! :) :sweat: |
For both parallel and serie charging you can find special balancer cables, boards and even compleete modules to connect 2 batteries to a charger.
Here's a couple options for you:
http://www.rcjuice.com/t-plug-deans-...harging-board/ http://www.rcjuice.com/t-plug-deans-...ead-6-battery/ |
I use Paraboards from Buddy RC.
http://www.buddyrc.com/power-system/...rge-board.html Just pick the configuration that makes the most sense for your batteries. |
On a parallel board there are balance ports for each battery used.
The only thing that might mess you up is that the 235 being just plug a play unit has a Battery capacity range: 50-9900mAh , Not sure what happens If you try and charge a larger capacity battery since it is all electronically controlled . When you parallel charge you are adding the capacity together So you would be limited to 2 4500 mAh batteries being charged with a parallel board with your charger . You might want to just get the onyx 245 model So that you can charge 2 batteries at once and not be worried about using the charger outside of its operating parameters |
Originally Posted by strykerakamack
(Post 14001194)
With my charger AC/DC 50W i bought a paraboard for parallel charging and i could charge 3 equal lipos at the same time wither 2s-3s-4s-5s-6s.
All 3 have balacing plugs for each other... Just get one of those boards...there are even 6 lipo capable! http://i206.photobucket.com/albums/b...pse76998ed.jpg |
Originally Posted by targetingxmod
(Post 14011069)
All 3 have balacing plugs for each other... Just get one of those boards...there are even 6 lipo capable! |
| All times are GMT -7. It is currently 01:36 AM. |
