-   -   novak bl motor problem. (https://www.rctech.net/forum/radio-electronics/872884-novak-bl-motor-problem.html)
turbo scorpion 04-18-2015 04:38 PM
I have a novak 17.5 bl and novak ss+ esc. Did the setup and when i pull throttle lights blink but motor doesn't turn.
If i spin the motor with my fingers it will start going and i can control speed with throttle.
Does this indicate a problem with the motor or the esc?
Can i use a volt meter to help determine the problem?
If its the motor does novak have a lifetime warrantee?
What could be the problem with the motor?
