bec or no?
ok here is my esc for starters, castle sv3. will i need a bec for this servo: http://www.hobbyking.com/hobbyking/s...FWxo7Aod00YAFA thats all folks!
ITS A BIRD! NO! ITS A PLANE! NO! ITS A BUMP!
To get the full potential, a bec would be ideal but, it will fail eventually. Best to buy a high volt servo like the trackstar ts-920 and buy a high volt servo harness. A guy on eBay sells them for $5 I think and they give power straight from the battery so you get full power potential.
so i high volt harness takes power from the battery to power the servo? well hell i didnt know those were made! may well do that but then i am limited JUST to high voltage servos, which isnt a bad thing i guess so i think i may well give that a shot for a good bec and a cheap servo you are spending about the same as a better servo and a hv harness so i guess it balances out think i will do that when i have the need for a high power servo but when i dont like in an onroad car then i guess i can think of something else heck a good traxxas 2055 would be just fine but mine is trashed i have beaten it to hell and drove it in the rain thats what is in my rs4 only becasue it had the most power of what i have on hand (2 nearly dead trx 2018's and at the time i had some ecx/spektrum servo but i am using that in a hobby grade electronic swap i am doing on an old nikko boat)
Originally Posted by ManDime
(Post 13944724)
Perhaps try a stutter stopper / glitch buster / capacitor in the receiver first, that seems to solve most issues. If it even has issues to begin with. Much simpler and probably more reliable than a BEC.
Originally Posted by thatguyyouknow
(Post 13944702)
Lets see if anyone gets this silly reference :) |
Originally Posted by Dave H
(Post 13944807)
http://upload.wikimedia.org/wikipedi..._series%29.jpg Lets see if anyone gets this silly reference :) |
(Post 13944810)
i get it :)
ya i found one: http://www.amazon.com/voltage-servo-...+servo+harness
Why are you all worried about the BEC voltage from your Castle ESC when the servo you've chosen isn't even a HV model?
Originally Posted by Yosh70
(Post 13946271)
also i found bits to make it your self and it costs about half as much this is what you need:http://www.amazon.com/dp/B008TKMC86/...I3FPXC9DG07W64
http://www.amazon.com/dp/B00HWLZDRA/...I1X609E8BM96AQ |
| All times are GMT -7. It is currently 10:57 PM. |
