-   -   Airtronics 3s compatible rceivers? (https://www.rctech.net/forum/radio-electronics/870317-airtronics-3s-compatible-rceivers.html)
enem178 04-01-2015 06:01 PM
Just picked up the arrma kraton and I'm running 2 3s lipos. I want to drop the rtr transmitter and run my MT-4s but none of the airtronics rx's seem to be able to take the 22v that the lipos put out. Looks like most of the rx's go u to 7.4v and the rx461 can only support 2s. So I'm I looking at the specs wrong or are there no 3s compatible airtronics receivers?? Thx
wingracer 04-01-2015 06:16 PM
No receiver on earth that I am aware of can support 3s. That's why your speedo should have a BEC supplying the receiver with somewhere between 5 and 7 volts. If not, you will need a receiver pack or external BEC.
Also if you are running 2 3s packs wired in series (which appears to be standard on that truck) you are actually running 6s.
enem178 04-01-2015 06:46 PM
Ok so what actually happens is the speedo gets the power 1st and then knocks the voltage down and sends it to the receiver? If thats the case I should be good with just about any receiver..no? Your right, I meant 6s.Thx
enem178 04-01-2015 06:47 PM
Also what does BEC stand for?
wingracer 04-01-2015 07:11 PM
Battery Elimination Circuit. Back in the old days, you had to run a separate receiver pack or some sort of voltage dropper to power the receiver until speedos started coming with BEC built in.
enem178 04-01-2015 07:43 PM
Cool..Thx!
