-   -   Hobbyking 120A Sensor/Sensorless ESC (https://www.rctech.net/forum/radio-electronics/866474-hobbyking-120a-sensor-sensorless-esc.html)
Iceman2772 03-08-2015 08:38 AM
Hi all,
I've got the above but after setting up with a Hobbywing (x-car) 8.5T motor (sensored), it spins in the wrong direction.
Despite testing with several versions of available ESC firmware, I have been unable to get the ESC to change the motor spin direction. When i perform a 'servo reverse' on the transmitter, the spin direction remains the same (wrong direction).
Does anyone have any suggestions for me to try?
Cheers!
chadp 03-08-2015 10:21 AM
You calibrated after changing TX settings?
GerryH 03-08-2015 08:37 PM
Just to confirm, it should be spinning counter clockwise when looking at the side with the output shaft.
I agree it's probably not calibrated correctly. I've got 2 of these and they spun correctly out of the box.
Iceman2772 03-09-2015 06:07 AM
Hi chadp,
Yes... i and my friend tried calibrating it (neutral, full throttle, full brake) several times but to no avail... :(
Iceman2772 03-09-2015 06:10 AM
Hi GerryH,
Actually... i need it to turn clockwise (looking at the side with the output shaft)! I'm running a durango 410 but with a motor seiki chassis.
cghomann 03-09-2015 08:10 PM
Originally Posted by Iceman2772 (Post 13894227)
Hi GerryH,
flip your gear diffs
triplesix 03-10-2015 02:01 AM
+1
What he says! Diff Cases installed upside down. The screws hexes face down.
Iceman2772 03-10-2015 05:09 AM
Hi cghomann & triplesix,
did just that last night... mystery solved! tks!!!
