Tekin RS V1 Issue
Having an issue with one of my Tekin RS esc's. When powered up the esc works fine. Throttle input is given through the radio and vehicles moves as it should. However when the wheels stop moving and the vehicles comes to a rest , when the throttle input is given again it will not move. If the vehicle is them bumped or given a push start it takes off fine.
Anyone else have this issue before and know of a fix? Thanks, |
Originally Posted by SRC_DRIVER
(Post 13858872)
Anyone else have this issue before and know of a fix? Thanks, If that all looks good, power everything up and watch to make sure the lights blink as you slowly spin the rear wheels. |
A q for Randy Pike. In Tekin info over older products i can read on RS (G1) that it can operate 1s Lipo, when i download the document it only shows 2-3s Lipos. Whats right, RS g1 1-3 lipo or 2-3lipo? Where about to run 1/12 on 1s here and need to know if my old RS will do! //Thanks
Originally Posted by jannedwr
(Post 14189729)
Originally Posted by Andy Koback
(Post 14189760)
It will work fine with one cell but you will need to use a booster or receiver pack.
What is ur pinion/Spur ratio? B4 you condem sensor cable. Reset your EPA to 100%, then try recalibration. What model you running?
(Post 14189823)
Ok thanks for fast answer!
Tekins were advising TQ Booster for 1S lipos or 12th scale. |
| All times are GMT -7. It is currently 11:02 AM. |
