-   -   bec vs power cap (https://www.rctech.net/forum/radio-electronics/862997-bec-vs-power-cap.html)
thatguyyouknow 02-15-2015 11:04 AM
bec vs power cap
what is the difference between a bec and a power cap they look very similar and i am not shure which to get. all i need it to do is supply power to a high voltage servo and the castle bec sucks
BigBadDogg 02-15-2015 11:52 AM
Hi
A power cap..aka. glitch buster.. will only Keep voltage from going below your desired volts say its 6vdc.. that will last for a short time as in less than a few micro seconds .all depends on caps size as in micro ferrads..its a boom and then gone till cap recharges.. also micro seconds.
A bec is hooked to your power source .battery.. and does not have a time limit.. it is constant supply. at whatever the bec is set..say 6vdc 5 amps.
There is a Giant difference.. you might need both..
have you set the castle bec on a higher voltage?
Yosh70 02-15-2015 11:55 AM
Which Castle ESC do you have? If just a Sidewinder version, then you cant adjust the BEC voltage.
If you need to power a HV servo to 7.4V, then you need an external BEC. A capacitor that plugs into your receiver would help with brownouts caused by low voltage to the servo but wont increase the output like an external BEC.
Castle makes one that you wire in, and its adjustable via Castle Link.
BigBadDogg 02-15-2015 01:09 PM
all castle ESC or BEC are adjustable via the castle link..
DRTMI 02-15-2015 06:19 PM
No, they are not.
Yosh70 02-15-2015 06:35 PM
I wish that was the case but I found out that all SW versions and even older MMM's (Gen 1) dont have that option in Castle Link....unless you know a trick?
thatguyyouknow 02-16-2015 07:08 AM
thank you all! for bec adjustments on sv3 is that on pc only because there isnt an option on the card
platgof 02-23-2015 07:36 PM
For some reason I cannot get the Castle BEC to work with my Savox 2271 high voltage servo. I adjusted it to 7.4, and the servo moved left and quit, did this twice. I did not want to push my luck, and quit messing with it.
thatguyyouknow 02-24-2015 05:03 PM
could that be a servo issue? what idiot lights came on the esc like what color, are the flashing
