1 hand controler work 2 different recievers? >
Old 01-18-2015, 01:00 PM
Default 1 hand controler work 2 different recievers?
I bought a TRAXXAS Grave Digger without a hand controler. I have a TRAXXAS Stampede brushed 4x4. Can I use that hand controller to operate the Gravedigger if I run them at different times? If not what other options do I have?
Thank you
tvmax is offline
Old 01-18-2015, 01:38 PM
Yosh70's Avatar
Trader Rating: 17 (100%+)
I dont think the Traxxas Tx supports multiple models so if anything, you can run them both if you re-bind each time....both Traxxas receivers correct?
Probably have to make adjustments on the transmitter for each RC as well.
Pain in the b*tt but unless you purchase another Traxxas transmitter or get a radio system that can support multiple models, thats about your only option.
Yosh70 is offline
Old 01-18-2015, 01:43 PM
So I can purchase just the original hand transmitter for the TRAXXAS Gravedigger and not the reciever?
What does it take to bind or rebind?
tvmax is offline
Old 01-18-2015, 01:56 PM
go on ebay there are many chop shops just buy a traxxas controller and receiver set for around $25-40 i dont remember
rc car freak is offline
Old 01-18-2015, 02:02 PM
Do I have to get anything special or any TRAXXAS transmitter and reciever combo?
Thank you for your help so far.
tvmax is offline
Old 01-18-2015, 02:06 PM
Yosh70's Avatar
No, any Traxxas transmitter should do.
Yosh70 is offline
Old 01-18-2015, 03:07 PM
If it's a 2.4 model it can control more than one rx. It doesn't have model memory so you'll have to adjust trims when you switch. I have a few paired to one tx.
SpongeX is offline
