How to change the settings with XeRun 120A using Hobbywing program card
Total Newbie - I did use the search feature .......
I have XeRun 120A and using HobbyWing program card - I see that there are 10 pre-program settings 1*modify, 2 zero degree etc etc... I would like to change some of those pre-program settings on any of the settings. I pick the setting I want and save it but the asterisk doesn't change after saving it. Using Item to move around - and pressing value to change it then ok to save it. Please help, I am sure I am doing something silly and overlooking something simple. Thank you for your time. This is a setup for Team Associated B5M an will be doing "stock" with a 17.5 motor. Thank you thank you thank you. |
Thank you very much and will post there too!!!
| All times are GMT -7. It is currently 02:06 AM. |
