-   -   need 4pks help (https://www.rctech.net/forum/radio-electronics/853764-need-4pks-help.html)
Budah 12-25-2014 11:44 PM
need 4pks help
was setting parameters last night batt went dead shut off ,so I charged it plugged it back in "full charge 6.6v correct polarity " and it will not power up any suggestions ? thanks budah
B16A2 12-26-2014 04:05 AM
Start by checking the battery to ensure it did not fail during the charge process. Check it under load eg a 5W globe should do it.
Worse case scenario the EEPROM in the 4PKS got corrupt during the power failure if the write to it was incomplete. If this is the case then rewriting the data from a known good 4PKs will do the job. Or possibly a fuse blew in the 4PKS.
Budah 12-26-2014 08:40 AM
thank you I will try that tested batt was fine under load
B16A2 12-26-2014 03:35 PM
After some thought a corrupt EEPROM should only result in corrupt settings values.
Did you try to power the 4PKs with a Lithium Polymer battery ?
