2s to 8s Balance Adapter?
Hey, I really hate balance boards. Thought I'd get that out of the way.
I've got a new charger with a single type of balance port (8s) but I only ever run 2s batteries. So, to balance while charging, I need to use balance boards. My old charger had multiple balance inputs from 2s to 6s and on that I used a simple 2s charge/balance lead I built myself. What I'm wondering is if anyone makes a really short 2s to 8s balance adapter, or I'm building one myself. (Should be pretty straightforward, but I'm feeling lazy.) Let me know if you know. Thanks! |
what kind of charger?
possible your just supposed to plug your adaptor to the first 2 pins in the 8s adaptor? |
Yes, you can use the 2S connector and just plug it into the 8 pin connector, assuming they are the same type. As you can see, the wiring is the same regardless of number of cells. For my 308duo, I just trimmed off the tab on the left side (tabs facing up) and plug it into the far right side of the 8 pin connector. Just need to make sure the negative on the balance connector is in the right place.
http://www.tjinguytech.com/_/rsrc/12...=117&width=200 |
Originally Posted by monkeyracing
(Post 13728940)
| All times are GMT -7. It is currently 11:57 PM. |
