Can't discharge lipo to dispose
#16
Forgot to mention I like the amber bulbs. Less obnoxious to the eyes. Think they have an A after the number if I remember correctly. 1157A
#17
Which is funny, my wife said it's okay if I build a track in the backyard as long as it doesn't look cheap...does that mean she's giving me permission to go all out? I'm thinking so.
#18
No actual lithium metal or other heavy metals in a lipo pack. According to the air gurus over at rcgroups a discharged lipo pack is safe for the environment.
#19
Recycling is still a good idea regardless. Including for the plastic cases, copper/wiring, etc. Radio Shack, Home Depot/Lowes, perhaps your trash deal or community has recycling, etc.
#20
If for some reason one of the cells is damaged or disconnected from the circuit, you might be able to discharge the cell(s) using the balance connection.
I can't post the link yet (not enough posts), but if you search ebay for:
"RC Voltage Lipo Battery Meter Tester Indicator 2-6 cells LED Panel Voltmeter G9"
...you will see a $1.88 device (free shipping from Hong Kong) that will tell you the voltage of each cell and the total pack voltage. I bought one of these, and for the price, it's a no brainer. Or you can use a multimeter to manually identify the flakey cell.
Also, I've never done this, and clearly there is some risk involved, but on Youtube there are some videos that detail the dis-assembly of packs and removal of bad cells. You could theoretically build a new pack using good cells from other packs. There is a lot of risk to this I thought I'd mention it. The videos are interesting to watch even if you don't intend to start cutting open your bad LiPo packs.
#23
well the instructions from trakpower that was posted here says leave in the salt water 2 weeks. but discharge it another way first. throwing a fully charged up lipo in the saltwater doesn't work. like all the dolts on youtube do.
I use 2 55w halogen lights from a crashed motorcycle. still took a long time to discharge a 4s battery.
#24
Don't do the "Battery Bath" as Venom instructs you to do on their email. The battery will blow up! Long story short, had a new battery go bad, Venom sent email to do Battery bath, did like said to do, POP!
#25
I did this method, as mentioned in the post. All went well and the battery was in the trash shortly after.
"Forgot to mention I like the amber bulbs. Less obnoxious to the eyes. Think they have an A after the number if I remember correctly. 1157A"
#26
I just use a MR16 12v 50w halogen downlighter bulb to drain my batteries. You can get them for buttons anywhere.
