Understanding a external BEC
I'm sure I have this right, just want to verify so I don't fry something.
My brother currently runs a 1s lipo on a mamba pro 1 cell ESC with a 2s life receiver pack. He wants to simplify and only charge one battery. Problem is the ESC has no BEC in it. Looking at this BEC http://www.hobbyking.com/hobbyking/s...SBEC_UBEC.html Is it as simple as just tapping the leads from the lipo, switching to 6v and connecting it to the receiver ? From what I've read, since the ESC has no BEC there is no need to cut the red wire, correct ? Finally, does the balance plug coming out of the lipo have enough AWG to tap power from to power the receiver ? It will be running a Savox 1256 servo and transponder. The rx is a Futaba 301 I believe, the one that comes with a 4pls. Thanks. |
The BEC can not put out more voltage than the battery is supplying. You would a booster of some sort. Novak used to make one, don't know if they still do or not.
Originally Posted by reaper7534
(Post 13627363)
I left out the one critical piece of information...... he is changing to a 2s. That's what I get for composing on a tablet.
Since he will be using 2s packs it it will be fine. I put my BEC into the battery plug on the ESC. I would not use the balance leads as they are usually very small wire and only see 500-1000MAh.
(Post 13627363)
| All times are GMT -7. It is currently 11:50 PM. |
