Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 10-13-2014, 12:10 PM   #1
Default Who makes a gauss meter?
Looks like the Trinity is discontinued for some reason. Are there others?
Sean B. is offline   Reply With Quote
Old 10-13-2014, 12:19 PM   #2
tessty71's Avatar
Trader Rating: 16 (100%+)
Look here for most all motor measuring needs http://racersmeasurementsystems.com/main.sc
KSG SCX / C&M Mortorsports
Point R/C Raceway
tessty71 is offline   Reply With Quote
Old 10-13-2014, 12:38 PM   #3
Thank you sir.
Old 10-15-2014, 03:26 PM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
Make one?
https://www.youtube.com/watch?v=Z-Ut25cuTmA
This is 12 dollar of electronic components.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 10-15-2014, 03:36 PM   #5
patorz31's Avatar
Make one?
Can you provide some plans to build one?
Northern Alberta Scale Car Auto Racers Pres. and Promotions
SCHUMACHER RACING Canada,TEAM POWERS, Mon-Tech,Sanwa
patorz31 is offline   Reply With Quote
Old 10-15-2014, 04:14 PM   #6
Roelof's Avatar
It is based on a SS495A
http://docs-europe.electrocomponents...6b8009a37c.pdf
Working at 5v the zero point is at 2.5v. On one side there is a potmeter to adjust t0 zero. The calculated resistors for the 200mV digital meter is only to use the full range of the meter with the range of the hall sensor. Ideal to measure the differences between several rotors or with stockracing to detect illigal rotors.
If you want the real Gauss scale you need to calculate the right resistors.
The sensor needs to be on a 5~10mm distance of the rotor.
Old 10-16-2014, 11:10 PM   #7
Saw those on Superior Hobbies' website; however, they were always out of stock. So I bought the Fantom Facts Machine 2. While not technically a gauss meter, it does compare rotor strength (both the + and - sides) and provides gauss like numbers for each. Also provides stator coil resistance.
John Wallace2 is offline   Reply With Quote
Old 10-17-2014, 02:43 AM   #8
Roelof's Avatar
Looking at that one it seems to me it works the same as I have made. 12 dollar components or 179 dollar unit.... I do see a potential bussiness
Old 10-17-2014, 11:13 AM   #9
I'm sure if I had the skill I could build a gauss meter less expensive, but I don't.
Old 08-08-2017, 12:57 AM   #10
From looking at the specs of the SS495A it only works up to 670 Guass.
(Magnetic Range (Typical) -670 Gauss to + 670 Gauss [-67 mT to +67 mT])
Surely a hall sensor is required that can measure up to around 1700 such as the SS94A2D?
I built one with the Allegro A1302 but it seems to top out at around 1350 for all rotors I tested.
Your circuit differs to mine. Do the resistors increase the range? It seems even combined, the range could only be 1340?
dvaid852456 is offline   Reply With Quote
Old 08-08-2017, 02:16 AM   #11
Roelof's Avatar
I use the SS495 sensor on a small distance. The resistor devider is just to get the output range of the sensor within the 200mV input range of the panel meter. I am not interested in a Gauss value because when building several you need to set the sensor with all on the excact distance, I just have build them so people can compare rotors with their meter.
With a LRP X11 17.5 turns stock rotor I have over here I set the readout op arround 1000 by moving the distance of the sensor, that is the middle of the total range of the meter.
Old 08-08-2017, 02:27 AM   #12
Pinkz's Avatar
FACTS MACHINE v3 - BRUSHLESS ROTOR TESTER
It rubs the lotion on its skin or else it gets the hose again.....Yes, it will, Precious, won't it? It will get the hose! https://www.youtube.com/watch?v=cyn0DVSn96I
Pinkz is offline   Reply With Quote
