-   -   Receiver issues (https://www.rctech.net/forum/radio-electronics/839958-receiver-issues.html)
JayInthatZ 10-04-2014 05:38 PM
Receiver issues
I just took out my spekturm system out of my Mt4 g3.(Dx4c)
When going back to the stock system I had to bind the system again.But everytime i go full throttle now i lose signal now.I had a buddy of mines hold the truck up in the air.And when i punch it the receiver light goes Red and i would have to turn off the truck and turn if back in order for it to work again.If i go 50%throttle everything is fine.Range is fun.But as soon as I give it full throttle it loses signal again......I try to rebind the radio at least 20 times.Same thing over and over.I even change back to the stock servo....same thing...any idea..Fresh batt and fulled charged liops.....kinda lost here.
wrongchannel 10-04-2014 07:01 PM
Did you install a new servo? perhaps a Savox high voltage?
When the servos draw too much power they can pull the voltage down to where the receiver doesn't get enough voltage to run.
Did you reset the ESCs throttle and brake settings after binding?
Without seeing the truck, that's all I can come up with.
Good Luck
JayInthatZ 10-05-2014 07:58 AM
well looks like i found out my problem...i think.My buddy was the last to use my truck and just informed me that he ran it through a huge puddle and seen some white smoke come out from the truck.So I just opened up my esc and found 2 of the 3 black capacitor looks to have crack open at the top....Guess that's not really good.Gonna have to get a new esc
