-   -   MAKE ELECTRONIC COUNTER (https://www.rctech.net/forum/radio-electronics/837410-make-electronic-counter.html)
christopherE 09-20-2014 12:59 AM
Hi. This is a bit of off normal track. What I want to do is to count the number of electric pulses that pass thro a section of wire. I have a wheel with a cam that works a sprung switch to a battery connection that will provide the pulses that I wish to count. Voltage is immaterial- 1.5 AA or AAA. I must just count pulses thro a certain length of time. It must have a zero capacity. Can any of you clever people come up with a simple circuit that would do this?
Thanks in advance.
mick33b4 09-20-2014 04:02 PM
How high do you want to count? I built a counter circuit to count rubber band twists for the space derby for the cub scouts with three cd4026 ICs. Just google cd4026, and flip to images and you will get the idea. It works, but is very tedious as each pin needs to be connected to each led segment (×7 for each digit). Otherwise go the Arduino route. The boards are cheap, you will be able to display the result on a PC, but some programming skill will be necessary
