-   -   Airtronics rx 461 (https://www.rctech.net/forum/radio-electronics/826673-airtronics-rx-461-a.html)
rmtr 07-24-2014 01:53 PM
Airtronics rx 461
My son has a receiver in which the antena is broke about 3" away from the case. We primarily race indoors. Can I repair it ( I don't believe you can solder these antenas) or just try it and see if it gets enough signal?
brew99 07-24-2014 02:19 PM
You should still be able to use it. Carefully strip back the black outer insulator and any of the metal braid (shield) to leave a 3.125cm length of the centre conductor wire. That should be a 1/4wave at 2.4Ghz
glenng 07-25-2014 02:54 AM
just replace it. takes 10-14 days from this place.
http://www.rcmart.com/sanwa-107a4110...?cPath=36_1335
