Pls help HK 150 amp programming ?
3 Attachment(s)
Can anyone please tell me if any of the below attached programming cards will program the hk 150 amp esc:
http://www.hobbyking.com/hobbyking/s...s_Car_ESC.html Locally the below is all i can get and would like to know if it would work ? |
Does not look like any of those will work.
This is the one the site says is for that esc, http://www.hobbyking.com/hobbyking/s...dProduct=44872 |
thanks drtmi but these are really all i can get, having done more research i found that the turnigy trackstar 150 amp esc is very similar to the hk 150 amp esc, would the turnigy program card in my photo above not perhaps work ?
I really doubt that any of those will work with the ESC. Hobby King seems to have a different program card for each different speed control. You could try it at the risk of possibly trashing the card or ESC. More than likely though, it will just light up the first light on the card and not read anything else.
Originally Posted by DRTMI
(Post 13320601)
http://www.hobbyking.com/hobbyking/s...Tz85A_ESC.html |
| All times are GMT -7. It is currently 08:26 AM. |
