icharger 306b with FMA PL8 balance board
Hi guy's,
I've recently bought an icharger 306b and a FMA cellpro PL8 balance board. I can not balance charge! I get a connection error message. It will fast charge but not balance charge. Do I need a different balance board or is the a problem elsewhere?
Thanks Ian
Thanks Ian
Do you have the correct cable to connect the FMA balance board to a iCharger? I think it takes a special cable, I don't believe either the iCharger cable or the FMA will work. ProgressiveRC or BuddyRC would know and should be able to set you up.
Also need to make sure your batteries balance connector is correct for the FMA board.
Thanks Dave, yeah my batteries connect up and will fast charge but I must need the special adapter that you mentioned. I've done a few Google searches but I might need to email someone in the know how.
Thanks Ian
Thanks Ian
