-   -   Futaba 2PL Question (https://www.rctech.net/forum/radio-electronics/813910-futaba-2pl-question.html)
gdurivage924 05-17-2014 08:53 AM
Futaba 2PL Question
I am clueless when it comes to Transmitters, Receivers, and Servos. I don't understand the voltage outputs or anything. I have a Futaba 2PL 2.4Ghz Transmitter that I purchased a very long time ago, and then it came with an R142JE receiver. I just pulled my car back out of storage and am upgrading everything. I was looking at the R603GF and the R203GF receivers and didn't know which one to go with because I can't find the differences. Both would work with my 2PL, right? Also, will either of these receivers work with a brushless system and any digital servo?
Hoese37 05-17-2014 09:45 AM
The R142JE is not a 2.4ghz receiver. Are you sure it is a 2.4 system? If its not you wont be able to use 2.4 receivers. Does your transmitter have a long metal antenna or none at all?
gdurivage924 05-17-2014 10:49 AM
It has a long metal antenna, so you are right it isn't a 2.4 system. I got it way back so thats not surprising. I just assumed it was because whenever I searched Futaba 2PL all that ever came up was the 2.4 system. I guess mine is the Magnum 2PL. Looks like I will be in the market for a whole new system now. Any recommendations that are decent and not to pricey?
Hoese37 05-17-2014 05:04 PM
You don't need a 2.4 system. Brushless and lipo will still work just fine.
tmaxx26power 05-18-2014 03:57 PM
Exactly right. The Magnum radio will work just fine and now with everyone on the 2.4 kick you shouldn't have to worry about conflicting radio channels :nod:
gdurivage924 05-18-2014 05:03 PM
Thanks for the input guys. I went ahead and got a Futaba 3PL because I wanted a 2.4 system and model memory for other cars in the future, and something with FHSS for faster response times.
