Broken Motor/ESC/Sensorcable?
hey there,
i got some problems with my new brushless combo: I am running a Yakuza Boss 160A sensored ESC with a Leopard 4274 2150KV sensored Motor. Without plugging in the sensorcable the combo seems to work fine, see this video: www . youtube .com/watch?v=BKXs--_nS8A&feature=youtu. be but when i plug in the sensorcable the motor starts vibrating badly and gets warm almost instantly (i took it out and held it in my hand). Also it doesnt turn correctly and just seems to "stutter" i can't think of a better word to describe it (sorry but english is not my native language): www . youtube . com/watch?v=g3OGSQQGNlA&feature=youtu. be sadly i dont have a spare motor/esc/sensorcable here to switch the components out. Has anyone ever seen something like this before? Thanks in advance for your help! :edit: please fix the youtube links yourself since im not allowed to post videos yet |
Do you have the main 3 wires from ESC to motor correct, A-A, B-B, and C-C? With sensorless they can be different, but when running sensored they must be wired in the correct order.
http ://1.1.1.1/bmi/img.tapatalk.com/d/14/05/12/thumbnail/u9ubuna5.jpg
should be fine |
that link will not work 1.1.1.1 is not a likely internet address.
But I agree that the likely issue is the that the A-B-C posts on the motor are not properly mated to the A-B-C posts on the ESC. Doing this really confuses the sensored setup and will cause chatter and heat. On sensorless it can simply reverse the spin of the motor. If it is not that then you likely have a bad sensor wire or an issue with the sensor board in the motor, less likely is the sensored part of the ESC is bad. |
the link to the Image Works on another Forum, just remove the space After the http.
I wired everything fine, the cables are colorcoded so eben i should be able to connect Blue with Blue, red. with red. and yellow with Yellow |
Originally Posted by BenTheMan
(Post 13261951)
I wired everything fine, the cables are colorcoded so eben i should be able to connect Blue with Blue, red. with red. and yellow with Yellow Heres the pic BTW http://img.tapatalk.com/d/14/05/12/t...l/u9ubuna5.jpg |
yea i switched the blue and the red cable, now red pairs with blue and blue pairs with red:
youtube. com/watch?v=p2tt91xD7hI&feature=youtu.be looks like its working now, thx for the help! :edit: yea that must be it, the yakuza bl esc/motor are just the opposite to the leopard hobby/hobbywing esc/motors... |
| All times are GMT -7. It is currently 03:32 AM. |
