DX4S Setup Problem
Hey everyone, I just got my DX4S on Friday and have had limited time getting it setup, but the only issue I've really had so far is thT when I get it setup for my Slash, the steering end points seem to be very low, where I really can't turn the truck much at all. I'm new to the more advanced features of a radio like this and I couldn't seem to find any kind of end point adjustment. I tried the exponential setting, but that didn't seem to work. And advice on where to start with a basic setup would be greatly appreciated. Thanks! :)
Spektrum refers to the end point adjustment as Travel. Also make sure the dual rate is turned all the way up first if it has it.
Did you ever solve this? I am having the same issue.
New DX4S. First start at the beginning. Redo Binding TX to RX, then calibrate ESC by manual, Third, set D/R to 100%. Finish it off do setting on Slash.
Dual Rate is the knob marked Steering Rate ...
| All times are GMT -7. It is currently 06:47 AM. |
