-   -   Oscillating Throttle/Brake Servo (https://www.rctech.net/forum/radio-electronics/809977-oscillating-throttle-brake-servo.html)
Palebushman 04-28-2014 07:02 AM
After a 'Work-out' around the track yesterday with the JQ WE, I came across this rather strange behaviour with my Throttle/Brake servo.
The breed of the Throttle/Brake servo is a Hitec HS-7945TH Multi-purpose* and the receiver is a Sanwa RX-451R 2.4GHz FHSS-3 Super Response.
Power is supplied from a Dynamite 7.4V 2000Ah Lipo pack that still had a 90% charge at the time of observing this strange behaviour.
What's happening:- The servo is oscillating steadily and quite slowly, windscreen wiper speed, approximately 5'-10' either side of its neutral position.
Even if I turn the transmitter OFF (BTW, the engine has been shut down) this steady oscillation of the servo continues.
Once I apply the full throttle or brake command, the behaviour stops, but when I release the trigger for it to return to neutral,
that strange oscillating behaviour starts immediately.
Any clues to the cause of problem would be much appreciated.
rhodopsine 04-28-2014 07:19 AM
I'm no expert, but it looks like the pot in the servo might have an issue. It seems like it's trying to center and never actually achieves it.
Martin Paradis
ffejrxx 04-28-2014 08:14 AM
sounds like a bad pot in the servo
or maybe a broken tooth on a gear
Palebushman 04-28-2014 03:12 PM
Many thanks Martin and you ffejrxx.
All the gears check out okay, but I suspect the 'pot' may be the cause of this issue. I forgot to mention that these servos were not new when I purchased them from a mate, who assured me that they had hardly been used. :sneaky: He uses servos without their mounting grommets!! I'm pretty sure that the 'pot' brush/wiper would not like that, as the engine vibrations would cause bounce or hammering of the brush tips on the carbon track.
Getting a replacement 'pot' will be costly, so I will take this servo out and use it for spares. I see that in RCTech, many favour the Savox servos, so maybe that's the way to go for reliability.
Thanks for your tips guys.
ffejrxx 04-28-2014 06:09 PM
the pot in the servo should be fairly cheap (under $1 from mouser/mcm ect..)
just gotta take it apart and get the model from it
http://2.bp.blogspot.com/-50KtwAX6Fv..._Breakdown.jpg
use a meter to measure the resistance across the 2 far poles
most are 5-50k ohm
and mark which wires go to which spots on it when replacing
