gens ace batteries - balancing issues
Bought two 7.4V 50C 5000mAh gens ace batteries. My buddy has the same ones and used them for a yr with no issues, they work excellent so I picked up two yesterday. Charged one and balanced is about perfect but I charged the othe and it did not balance, I'm showing 3.9 in 1 cell and 4.3 in the other which exceeds the 4.2 that each cell should have. I am going to cycle these batteries a few times to see if it will correct its self but I wanna see if anyone else has a comment on the issue??
Originally Posted by BuGgYBaShEr.28
(Post 13208576)
I had two different chargers (same brand) and they could not balance them. I then bought a new 350W charger and it was able to balance them all. Even though it took up to a couple of hours on some. It balances them all nicely now with no problems. Try different chargers, if you can, and be patient, allow several hours to pass. You should see, in this time, that the low cell slowly increasing the voltage. |
| All times are GMT -7. It is currently 11:23 AM. |
