Problem with my motor/esc. I'm confused
Hey guys, I'm not sure if it's the motor or ESC, or possible even batteries, but I'm having some problems.
The throttle is extremely weak below 3-5mph and it'll shut off if it cant get above about 3-5mph in about 1 second. Its bad enough to were if i floor it on a baseball field, I have trouble getting it started. I normally have to get off and back on the throttle once, sometimes twice as soon as it cuts out to get it to that speed. As soon as it goes below that speed, it's perfectly fine with plenty of power.
This has me quite confused, so do you guys have any ideas?
I'm running a sidewinder 1/8 esc and a reedy 550 motor in a desc410
Are you running a sensored motor/esc? If so try another sensor cable... If still no good try another motor to see if the sensors have gone in the current motor. Also check the calibration of the end points on the esc.
Hmmm. Ok has this only started recently? I'd want to check all my connections as a bad solder joint can cause issues. What batteries are you using? If they are quite low C rating then maybe they aren't capable of outputting the power needed for hard acceleration and the voltage is sagging causing the LVC to trigger?
Slo-there is no cog by hang, holding it off the ground it still accelerates very slow till that wheel speed. The ESC is new, the motor I bought used and this was its first run.
Dan-my solder joint look pretty good throughout. It doesn't matter how much throttle I give it, it always has troubles getting to that speed. My batteries are turnigy 5100mah 65c LiPos. At the end of the run, it still acted the same, not getting worse at the end
You said power feels poor below the 3-5 mph range and you mention flooring it in another sentence. I am curious how it operates if you drive it very slowly and accelerate softly. Does it still cut out if you do not reach your 3-5 mph? Does it feel normal?
I don't know if the answers will make for an easy diagnosis but it may help eliminate some possible causes. I am also curious if this is a smooth lack of power or if it is cogging, bucking, etc.
Its as of the esc cant give the motor anything other 1/10 power below that speed
