Brushless esc running from servo channel. >
Old 04-05-2014, 03:47 AM
Red face Brushless esc running from servo channel.
I have a brushed 4 in 1 esc could I plug a brushless esc and motor into a servo channel and get it to use that signal for its drive.
Just read somewhere saying that the throttle and servo signals are the same from the rx.
Next edition is offline
Old 04-05-2014, 04:03 AM
Assuming that's a typo in your first sentence, you mean a 4 in 1 (4 channel) receiver, then yes. The servo signals are essentially the same from receiver to ESC for brushed and brushless, and for servos.
The only exception I can think of is radio speed, some of the newer radios have higher speed modes that won't work with many older servos. Not aware of that being an issue on the ESC side.
Dave H is offline
Old 04-05-2014, 06:50 AM
ffejrxx's Avatar
the pwm servo signals are the same
you can put a servo on throttle output (for mech speed control or gas/nitro engines)
or multiple esc on a reciever (if you cut all but one of the power leads for them, so you dont short their power circuits)
ffejrxx is offline
Old 04-05-2014, 07:55 AM
This brushless esc has its own bec does it need its power wire cut out,since the brushed esc has its own power.
Old 04-05-2014, 08:24 AM
If you are using more than one esc, yes, remove the red wire from the servo plug on any extras as ffejrxx mentioned, be sure to insulate it well.
Possible tip, a short servo extension can be used, remove the red wire from it, saves the esc wiring to be used normally later for something else. Of course if you are careful the red wire can be removed, and then replaced when needed, just an option.
Dave H is offline
Old 04-05-2014, 08:25 AM
ffejrxx's Avatar
the escs can use their own batteries to power them
but only 1 should to give power to the reciever
ffejrxx is offline
Old 04-05-2014, 06:32 PM
Thanks saves alot of hassle.
Old 04-06-2014, 12:29 AM
So could I use wires where brush motor power output is as servo input signal to move back and forth,though the servo has 3 wires and brushed output only 2.
This escs off a 4ch heli and I want to use the main and tail rotor motor output signals to work servos.
Old 04-06-2014, 12:49 AM
ffejrxx's Avatar
the esc motor output cannot go to the reciever
for the reciever wires
servos will need 3 wires (-,+,s)
the tail esc will need 3 wires (-,+,s)
the main rotor esc will need 2 wires (-, ,s)
the input power from both esc can run off the same battery
ex. this but dont need fuses, or rx battery if 1 esc is running power to the reciever
http://static.rcgroups.com/forums/at...Untitled-5.jpg
ffejrxx is offline
Old 04-06-2014, 01:01 AM
DirkW's Avatar
Wait... so you want to hook up servos to the motor outputs of a BEC?
Should not work.
DirkW is online now
Old 04-06-2014, 01:15 AM
Here is the esc the thicker red and blue wire and the red and black right of it are the main and tail rotors 3-4ch can i get those to work servo.
If I knew which brushless converter could run it I would just use that but not sure which will work and the wait from overseas mail is slow.
So I could rig ailreon system up if not ill just use 2ch which will be ok.
Old 04-06-2014, 05:32 AM
ffejrxx's Avatar
ok, thats a custom reciever/esc board for the heli
if you convert it to brushless, you will need new reciever, and escs
or for testing purposes, just hook up the ground and signal (black, ,white) from one of the servo channels to your external esc (from the connector that goes to the reciever)
and use its own battery
ffejrxx is offline
