Separate lipo balancer
Ok, so I have a team checkpoint pro charger that was given to me by a friend because I'm just starting out in rc racing. My problem is that it doesn't have a balancer in it. Guys at the track say its a great charger but I need a balancer. I been on amain and they have a few but I'm not really sure what I need. I'm running 2s hard case lipos with inboard ports and a small port which I believe is for a balancer lead. What do I need to get?
I used this one before I got a charger with built in balancing: http://www.amain.com/product_info.ph...ttery-Balancer
It depends on what lead you have coming off the charger, but this is basically what you need to connect the battery: http://www.amain.com/product_info.ph...llet-Connector It has a 2mm bullet to plug into that balance port on your battery. |
Thanks Klaymon, that is kinda what I thought I needed.
| All times are GMT -7. It is currently 12:51 PM. |
