-   -   Need help with Futaba 3PMX (https://www.rctech.net/forum/radio-electronics/801933-need-help-futaba-3pmx.html)
armysoldier1073 03-22-2014 06:52 PM
I have built a Sworks BK1. I got the 3PMX so i didnt have a radio for every car. I got it figured out for my EP Cobra. But when i go thru the steps for the BK1, the throttle servo only reacts in brake and when it does it pulses. I have zeroed out all the settings a few times and started over thinking i forgot a step or miss adjusted one. But same thing happens. I have even changed servos and no change to the reaction. Any have this before or anything. Please tel me what im doing wrong.
Thank you.
armysoldier1073 03-23-2014 06:32 AM
noone?
MarkA 03-23-2014 09:51 AM
Were both servos you tried the same type/brand and if so, what are they?
armysoldier1073 03-23-2014 11:48 AM
Savox 1256, 1258tg
MarkA 03-23-2014 12:05 PM
Try the TX in PPM instead of HRS and then re-bind it so the RX picks up the mode change. Pulsing is often a symptom of a servo getting an output signal it doesn't like. If that doesn't fix it, I would try a new/fresh receiver pack. Savox servos are such power hogs that you never know what they will/won't do when they are not getting enough juice.
armysoldier1073 03-23-2014 12:57 PM
ill try that. thank you.
