Problem with Tekin Redline 1gen motor
Hello everybody
I have tekin redline 21.5 motor with mamba max pro esc on my axial scx-10 once car stopped shaft does not rotate, but twitches - more with sensor cable and less without it I dissasembled motor and all looks ok inside tried another sensorless motor and it works ok what's wrong? ps sorry for my english |
Dial your throttle trim back a little bit. Sounds like your hitting the edge of the neutral width.
I got this problem during normal driving
now tried to move throttle trims, nothing changed |
If you tried another motor and it was ok my guess is the sensor board on the gen1 is goosed.
replaced the Sensor PCB
no change any ideas? |
Sounds like either a sensor harness or esc setting.
Changed a harness, updated firmware on ESC and reseted settings to default ones.
Problem is still here So I think the problem is in motor itself How can I disassemble motor to check coils or with ohmmeter or somehow else? |
| All times are GMT -7. It is currently 06:04 PM. |
