iCharger 406 DUO Charger >
Like Tree99Likes
Old 04-04-2024, 03:13 PM
  #1156
RussF's Avatar
Trader Rating: 22 (100%+)
Originally Posted by gigaplex
Are you sure you only want to charge at 3A? 406 Duo is pretty big to bundle with a small PSU for such a low charge rate, I'd recommend just getting a small AC charger instead.
Yes, this would be for 1/28 scale type racing batteries. I have a large power supply for charging 1/10 type racing batteries at a much higher rate but its kinda overkill for these little batteries and pretty heavy for traveling with. I've been looking at small chargers and found a few of interest that I'm still considering. Most dont really do a good job of discharging, or at least discharging quickly. I just thought I would explore the idea of using my 406duo for travel but with as small of a power supply as I can find if one exists.
RussF is offline
Old 04-04-2024, 03:18 PM
  #1157
gigaplex's Avatar
I've been in that boat, I find my 406 duo way overkill for my 1/28 batteries. Those batteries don't really support high discharge in the first place, just about any charger will be fine.
gigaplex is offline
Old 04-05-2024, 10:52 AM
  #1158
RussF's Avatar
The cycling suggestion from one of the top racers was 2 amp charge and 3 amp discharge to get the lowest IR and highest punch out of the packs for stock racing. Same story as any stock racing, just on a smaller scale. The travel charger I currently have is the Ultrapower UPS4AC. It does 1 amp x 4 channels. Great little charger as I can do Lipo and Nimh at the same time. It gets the batteries charged ok, but no discharge or higher end voltage options. A couple chargers I've been considering are the ToolkitRC Q4AC, and the ISDT 608AC. Both are small and have their own power supply and will do up to 2 amps discharge according to the specs. At home I can use my 406duo with the normal power supply and do a cycle of 3A discharge followed by a 2A charge. So the original question was is there a smaller travel power supply that would power the 406duo and run those specs.
RussF is offline
Old 04-06-2024, 07:24 AM
  #1159
GerryH's Avatar
Trader Rating: 26 (100%+)
I'm assuming you want to be able to charge both batteries at the same time, you need something like the 72w 12v power supplies you can find all over the place. Will need to modify the output cable to match the iChargers input connector.
GerryH is offline
Old 04-06-2024, 11:15 PM
  #1160
Alexv2024's Avatar
What about wiring together a few bigger race packs? How many mah do you use in a run? 2 2s packs in series could easily power the charger for a ton of mini racing. Its probably what I'd do in your situation.
Alexv2024 is offline
Old 05-06-2024, 11:50 AM
  #1161
So just picked up an icharger 406 and had a question about the end charge voltage. All of the profile settings are default with the exception of charge rate which is 10amp for a 2s lipo. When the charge cycle is complete the pack voltage is around ~8.35 and cell voltage is ~4.17. Posts in this thread suggest bumping up the charge cell voltage to 4.21. Other reading suggests changing the balance settings to "End Current AND Detect Balance" along with setting the "Charge End Current" from its default 10% down to 2 or 3%. Which would be the desired approach? Its likely not even a real issue at club level racing but it is different from my other chargers. I'm coming from ISDT chargers and they always came off at exactly 4.2v per cell and 8.4v for the pack without having to change any settings.
gimpy racer is offline
Old 05-06-2024, 03:40 PM
  #1162
gigaplex's Avatar
I prefer to bump the final voltage up to 4.21. It'll charge quicker as it stays at a higher current for longer then stops without waiting for an extended period of time at a low current at the end of the cycle.
glennhl likes this.
gigaplex is offline
Old 05-07-2024, 11:05 AM
  #1163
Perfect, thanks!
Old 06-01-2024, 08:02 PM
  #1164
I am getting a 2400 error code, voltage matched error, the voltage of the balance port sum is lower than the output one, when trying to charge TRAXXAS 3 cell packs. I can charge TRAXXAS 4 cell packs with no problem, with the same leads. Any help would be appreciated.
courtlow is offline
Old 06-02-2024, 12:18 AM
  #1165
gigaplex's Avatar
What are the voltages of the individual cells and the total pack voltage as displayed on the charger?
gigaplex is offline
Old 06-20-2024, 01:01 PM
  #1166
danny d's Avatar
Trader Rating: 14 (100%+)
How do I set the hold voltage after charge? as in it keeps the voltage at 4.22 per cell instead of dropping down.
danny d is offline
Old 06-20-2024, 02:11 PM
  #1167
Trader Rating: 47 (100%+)
Any brick-style laptop charger rated at 12-24 volts and over 60 watts should fulfill this need.
biz77 is offline
Old 06-20-2024, 02:23 PM
  #1168
I don't believe there is a "trickle charge" setting...but, if I'm wrong, I'm also interested in knowing, as I've had the same problem. Since getting the 406 DUO, my only 'solution' has been to unplug the battery as quickly a possible (usually, within less than 1min) after the "charged" beeping starts.
Panther6834 is offline
Old 06-20-2024, 03:39 PM
  #1169
gigaplex's Avatar
Unplugging the battery doesn't stop the voltage sagging.
Andy Koback likes this.
gigaplex is offline
Old 06-20-2024, 07:36 PM
  #1170
Regional Moderator
disaster999's Avatar
There is a function for the ichargers, but I can only set it to keep the voltage for 5 mins. After that it would stop charging.
disaster999 is offline
