iCharger 406 DUO Charger
#752
I've got the same problem and would like to find a fix. Additionally, the second channel reads a super high temp (200*+) immediately when I plug in the resistor bank.
#753
#754
Had the same issue. Turns out one of the resistors went bad. Replaced them and good to go.
#755
[QUOTE=iTz Nicholas72;15381235]
were did you find and what kinda resistor?
[/QUOTEwere did you find and what kinda resistor?
#756
Asked in the 308 duo thread but not sure if traffic on that thread is low or whatever, so I guess Ill ask again here since function wise its the same
Anyone know if icharger has a function where it maintains the charge of the battery after its done charging? ISDT chargers has a function where after its finished charging it will keep the voltage of the batteries at 4.2v/cell until you pull it off. Pretty useful to me when Im at the race and want to have the most power available as possible. I was able to find the "keep" function inside the menus where it will keep the charge of the battery for 5 mins, but after that it stops.
#757
[QUOTE=toepush;15381336]Cutequeen 2PCS 100W Watt 1 Ohm Aluminum Case Wirewound Chassis Mounted Resistor (pack of 2) https://www.amazon.com/dp/B01LYMCOPY/ref=cm_sw_r_cp_api_i_rMBsCb1HH4GE0
#758
[QUOTE=iTz Nicholas72;15381689]
Cutequeen 2PCS 100W Watt 1 Ohm Aluminum Case Wirewound Chassis Mounted Resistor (pack of 2) https://www.amazon.com/dp/B01LYMCOPY..._rMBsCb1HH4GE0
thank you sir
#759
I have a 4010 and the 2nd channel will read the cells but will not charge. I keep getting error 1305. Do you guys know where I can send my 4010 to get it repaired?
#761
#762
R/C Tech Elite Member
Just put together an instruction sheet for setting up the iCharger for using the Resistor Banks.
https://onedrive.live.com/redir?resi...int=file%2cpdf
thanks
#763
Can you charge 1s lipo off main leads? I keep getting connection error. How would you charge a 1s transmitter pack? Thanks
#765
