iCharger 406 DUO Charger
#736
It depends on what batteries you are trying to charge. You can charge 2 2s batteries at 40A each with a single 1200 watt server power supply. Doesn't really matter though because he was asking about discharging both batteries at 40A at the same time, which is possible only if you power the charger off a lead acid battery instead of a power supply.
SlotCarRacer, are you trying to discharge two batteries at once because you are using two packs together?
#738
There are a lot of guys charging multiple 2s batteries @ 40 amps off one 12v power supply, as you can see in the video above.
#739
For anyone looking for a carry solution, I have found the Jconcepts universal radio bag to work very well. Picture doesn't show cables but there is plenty of room.
https://www.amainhobbies.com/jconcep...co2338/p417253
#741
Does anyone know where to find any 3d printer files for the charger stand?
#742
Discharge problem
My i406 Duo now reads voltage in the second channel as soon as I plug in my resistor bank. The charger now thinks the second channel is in use, and won't allow a discharge.
Anyone have a similar problem? Any fixes?
#743
#744
#746
#747
Have a 406 duo, and last few trips to the track one side will show a connection error and not charge, swapped boards, swapped cables etc... nothing changes so I just charge from the other side. Fire the charger back up a day or so later and it works fine until you run a few packs then it does the same thing? any idea's
#749
#750
Why paint did you when spraying your charger
