iCharger 406 DUO Charger
#31
Found the link to the standalone discharger:
http://www.racersmeasurementsystems....r-Dumper-W.htm
To date, I have yet to find any reviews on it.
$199 ouch
you can also make an old school bulb discharger Matt.
#32
Matt. I have heard of people using this to discharge. they come in different watt ratings.
I got the info from here
http://www.helifreak.com/archive/ind.../t-475511.html
500watt 2ohm
http://www.ebay.com/itm/5-500W-2-Ohm...3D310579823852
200 watt 2ohm
http://www.ebay.com/itm/like/390366399443?lpid=82
500watt 2ohm
200 watt 2ohm
My guess is no to all three.
#34
Randy, feel free to come talk crap to me in person when I am at w3. I was posting info I found for Matt. Please troll me IRL, I welcome it. And yeah, I have had a few chargers and done regen charging. I have been looking into resistive regen for a while. The simplest method for a 20amp load is to use discharge one battery while charging the other on the other channel. Not everyone wants to have a mule pack to use for the work. But again, I welcome you to come say hi to me in person, and stop being a keyboard hero
If somebody is asking for help with something that has the possibility to go wrong like a fire starting and a house getting burned down if not done correctly needs tips from somebody that has experience with the task. If you give advice or a tip on how to do something you have never actually done yourself and it results in somebody's house catching on fire are you going to be responsible for the tragedy?
Telling somebody what tires to go buy and them wasting $20 because they didnt work as stated is a lot different than something that could end bad if not done correctly.
Think about it for a minute
And yes, I did have a lipo fire ( in an open area while trying things ) as a result of messing with this to see what can and cant be done
#36
Ok so this has been bugging me...not that it really matters but why the heck didn't they call it the 408 Duo? I understand the 308 not being called 3010 as it is in a different case...but they have a 306 and this 406 isn't like that it is like the 308, so why not call it 408?
#39
#40
#41
Correct. The higher cells are mostly used for airplanes & helis, thus the different models.
#45
A separate discharge device makes things a little simpler in the pits, no need to set up a regen or expanding deal or use a dummy pack. Or switch the charger setup back and forth between modes.
